Vl 304 conversion
402rat, Apr 20, 5:57pm
anybody done this conversion,just thinking bout doing it soon,will be running t5 box,all gear will be from a 96 or similar as i don't want it from a vn ,what are the main parts i will be needing!thanks
schultzie, Apr 20, 7:11pm
you again.whats wrong with VN gear! Exactly the same as VS anyways with the odd exception. Front v8 x-member (or K frame if you hail from aus) from VB-VP, radiator, engine with mounts,box, flywheel (pretty sure they are all 6 bolt), pressure plate, clutch plate, thrust bearing, clutch fork, clutch cable, pedal box (VB-VL = expensive as hell as you can only use the 6 & 8cyl one), bellhousing, slip yoke. If you had a complete donor car (good luck) then that save yourself alot of time & $$. You will have to get the driveshaft made as only the VL had this engine/box combo factory & VN onwards the car is longer so the shaft from this is no good. Oh yeah & the stick surround for the centre console or just modify the auto one. I see your wrecking a vl calais. DO you realise that some of the parts in your questions you need for this conversion not to mention the car itself is a manual.
402rat, Apr 21, 6:22am
haha me again!yeah i can get most parts anyway.im not sure if the vs radiator will fit and do i use a vn v8 k frame and what pedal box do i use.
schultzie, Nov 23, 12:02pm
you need the pedal box from as i said above from VB-VL 6 or 8 cyl car as the 4cyl ones have a different pivot. The engine x member from a vn v8 will work. As for the rad. Excuse me if im wrong as its been years since i did mine but from memory the rad mounts from VL are 420mm apart. VK & older are 460mm. Am not sure if VN onwards match as I have a pre VL car but i dont see why it would be. If VS mounts match, its all good
