Headlights not working?
jono2912, Apr 19, 6:24pm
Headlights still don't work, new relay, and fuse, switch works. What next!
(1991 Toyota Camry SV30)
franc123, Apr 19, 6:29pm
Not being rude but have you checked both the bulbs.!
jono2912, Apr 19, 6:39pm
Good question, my own fault as I should of mentioned park don't work either.
jono2912, Apr 19, 6:51pm
Highbeams work, but only when I pull switch back.
franc123, Apr 19, 7:13pm
if all of the front bulbs, including the park bulbs are all OK it is still pointing back to a switch problem.
jono2912, Apr 19, 7:15pm
Okay, cheers I'll have to have another look tomorrow.
Anyone else got some ideas!
quickbuck, Apr 19, 7:35pm
That would be your "Passing" function. Not used in NZ.
I am not an expert, but I suspect that when you hit the "Pass" the current actually by-passes the relay! Could be wrong.
So, it could be a short in the wire before the relay!
At least you have proved the bulbs are good ;)
johnf_456, Apr 20, 6:45pm
They are used in auckland, a flash to say you can pull in etc.
quickbuck, Apr 20, 6:51pm
Well, yeah. They are very handy communication devices.
Thing is, if you actually use them for their intended use in this country, peoples ego's take over and they think the driver behind them is an arogent dick who thinks they own the road.
In truth, it is a person who is warning you that you are about to be overtaken. Hold your line, don't spook, etc.
