Mig tickets 4177 whangarei
bellus_sybarite, Apr 18, 1:41pm
who can i talk to in whangarei about getting my welding tickets !
h.e, Apr 18, 1:51pm
got a polytec up that way!failing that ring a few engineers find out who they use
rob_man, Apr 18, 2:54pm
I thought someone was selling rides in a Russian fighter.
daz59, Apr 18, 3:53pm
You sure your not talking about 4711 welding ticket!
h.e, Apr 18, 4:21pm
4711 is a thing of the past.i thought that was a typo,not sure what the new one is.get to sit it in august looking forward to only one plate rather than 3
bellus_sybarite, Apr 18, 5:38pm
sorry just a error.
bellus_sybarite, Apr 18, 5:39pm
How long is the plate and what position !
franc123, Apr 18, 5:43pm
4711 doesn't apply to just MIG though does it!I thought it was ARC, or is it electric welding generally!
im_andrew, Apr 18, 7:18pm
Yeah 4711 applied to all arc welding processes. I held 4711 in MMAW, GMAW and FCAW. But as others have said, 4711 has been phased out now and replaced with something different.
franc123, Apr 18, 7:23pm
So what is the new qualification then!I was considering doing a 4711 course but won't bother if its being changed!
h.e, Apr 18, 7:25pm
i believe its the same test,the main difference is if you sit downhand you only get that position,if you sit vertical and pass you get given downhand,if you sit overhead and pass you get the other 2.
im_andrew, Apr 18, 7:48pm
Also, if you are going to do welding certs, do MMAW (stick) first. It gives you a really good grounding in all other welding processes, and its a hell of a lot more useful than just bare wire mig.
EDIT if you think about it this way,most wire feed (MIG) processes are like driving an automatic car, while stick, TIG and even gas welding processes are like driving manual.
im_andrew, Apr 18, 7:57pm
What if you only pass horizontal!
unideck, Apr 18, 8:07pm
h.e, Apr 18, 8:18pm
horizontal 4711 went out in 1988-89.it was covered by having both downhand and vertical.i havent sat the new tickets yet and only flicked through the paper work.reading that sort of stuff bores the sh#t out of me,and really i dont need to know all the ins and outs of it.but my understanding of it is i will do a overhead and get all 3 positions provided i pass,and because my currant 4711 was valid for 3 yrs the new ticketwill be as well
h.e, Apr 18, 8:24pm
now that would have to be the best advice i have seen ever posted on thesubject of welding
im_andrew, Apr 18, 8:25pm
weird, Im sure I had to submit a test plate for horizontal.
h.e, Apr 18, 8:30pm
the years may be out a year or so,but i only sat it once and didnt have to again.started in 87 think i sat it that year if not it was the next year
im_andrew, Nov 13, 3:48am
Na i did mine in 2008. though it might have been because I was thinking of doing ASME 8 and 9 so needed 4 positions for that anyway.
