Hi there have a silvertop 4age ae101 levin, and my check lights staying on all the time, and car is not pulling at all , tried too get codes out and no joy at all. any help would b great :)
pollymay,
Apr 15, 5:02pm
You need to pull codes, sounds like a knock sensor issue.
Bridge E1 and TE1 in the diagnostic connector and turn the key on, that should bring up the flashing codes. You can even bridge it direct at the ecu if you are really hard up and there are wiring breaks but that is something you should really sort out.
ola_bitchola1,
Apr 15, 5:07pm
it could be a air flow meter issue or blown/ leaking capacitors in the ecu ( a somewhat common fault showing up now that there getting on in age )
dent,
Apr 15, 5:08pm
Do you know why you couldnt access the codes. Is the check engine light a bright ornage or a dull red colour.
darrinleanne,
Apr 15, 5:09pm
i can not get flashing code up.
ola_bitchola1,
Apr 15, 5:12pm
i would say that the caps have gone in the ecu its quite common when that happens to get a ecu fault but not able to get any fault codes
darrinleanne,
Apr 15, 5:14pm
anyone got a ecu forsale then lol
darrinleanne,
Apr 15, 5:28pm
bright orange
ola_bitchola1,
Nov 2, 1:52pm
you can get them repaired but just get the ecu checked to make sure that is the issue
