Phone charging
jezebell, Apr 13, 10:38am
Yesterday I used the charger for my mobile in the car for the first time. So I had it plugged in to the lighter point and had been driving for less than five mins when smoke starts coming out from under the bonnet! Anyone else heard of this happening! Do you think it was the charger that caused it or just a coincedence!
pandai, Apr 13, 10:50am
It depends what the smoke was from.
If the smoke was coming from your dashboard, then it'd be more likely.
jezebell, Apr 13, 12:09pm
Hey thanks for the reply, nope it wasn't from the dashboard, it was from under the bonnet.
My partner thinks its unrelated but since I pulled the charger out, the car has been fine :/
tekaholics, Apr 13, 12:14pm
arcingout your earth.your wire behind it should be all melted now might pay to pull it apart an replace that one wire it will be just wire now no protective coating will be around that one wire now.an it may or will cause more problems for the vehicle from now on
tekaholics, Apr 13, 12:42pm
the wire would have been behind the dash but the smoke would have came out though the firewall in your engine bay yes under the hood.
jezebell, Apr 13, 1:23pm
Cheers, I won't be using that charger again, and will get it looked at - Im not a car person so won't attempt at doing it myself lol
crzyhrse, Apr 13, 2:44pm
Unlikely to be related. Smoke can't make its way from the interior to the exterior except via air vents and for that to have occurred the smoke would have been initially apparent in the passenger compartment.
russ18, Apr 13, 3:34pm
Sound unrelated to me.
intrade, Apr 13, 3:37pm
it be unrelated. i guess the charger still works! in charging the phone .
jezebell, Apr 13, 8:08pm
Just went to check and the charger no longer works, I dont want to ruin anything so I didnt try to force it - its probably just a huge coincedence though because my partner doesn't understand how it could be related either.
Although in saying that hes not a car person either, so will take it to a mechanic and see what the verdict is :)
pandai, Apr 13, 8:12pm
Try an autoelectrician first
jezz43, Oct 27, 5:48am
ive had something similar before. a chinese unbranded car charger, plug it in and it melts the back of the ciggarette lighter and some wires under the hood. turns out it was cos the previous owner didnt want to use the proper stereo wires and linked them off the ciggy lighter, caused something to go wrong and melted wires running to a relay. or so the sparky said
