the boot puller on my 1993 nissan sentra seems to only work with the key now, have cleaned all the working parts with brakecleen and crc, it worked for a few pulls then just clicks and i have to use the key again, how do i adjust it so the puller will work! thanks
jmma,
Apr 11, 4:20pm
There sometimes is a latch on the inside boot part to stop it working with the pullar, check for this
lookoutas,
Apr 11, 4:24pm
That's the deal. But if that fails - get johnf
jmma,
Apr 11, 4:27pm
Yeap, he will know for sure (o:
lookoutas,
Apr 11, 4:59pm
You need to get your cryptic brain into gear jmma. OP needs a puller!
jmma,
Apr 11, 5:11pm
OK just thought it was better than a poper, john will be along soon, he is still finishing the beers someone gave him, must have been a couple of bottles (o:
poohbear011,
Apr 11, 5:23pm
ok will try the latch 1st
i-n-horz,
Apr 11, 6:20pm
Ohhhhhh! sh!t.here we go.
jmma,
Apr 11, 7:58pm
Sorry, I thought John would be along to confirm this, I thought he was the Nissan expert, must be mistaken, he just knows about everything else (o:
sr2,
Apr 11, 9:12pm
Brave man, you'll probably be stalked for saying that!
bigracket,
Apr 11, 9:21pm
Dun dun dun !
shazeldazel,
Apr 11, 9:25pm
On the boot latch (on the car not the boot lid) there is a little lever that slides up and down. The up position allows the boot to be opened from inside the car, down disables it
Apr 12, 7:27am
as far as i know you have to push the leaer pulling is opening the petrol flap
poohbear011,
Apr 12, 2:46pm
no pulling is open, push for petrol, so i shoule remove the carpet etc around it and look for the little lever!
lookoutas,
Apr 12, 3:21pm
No no - the lever is on the boot latch - in the boot. Because it worked, then didn't work, it was probably set half-way in-between, and now it's gone to whole-off. You need to set it to whole-on.
poohbear011,
Apr 12, 6:34pm
ok will try that
poohbear011,
Apr 13, 9:17am
was just the latch halfway down, thanks alot
noswalg,
Apr 13, 9:23am
Never! stalking is to sneaky sneaky, he's more of a face to face type of guy <but only over the interweb>
lookoutas,
Oct 24, 8:46am
Good result eh!
Never forget the guy nutting-off coz we'g fixed his car and the back door wouldn't open from inside. Opened the door - flicked the "kiddy lock" off. and he had to stand there with a face full of egg. The solution is often very simple. But it's normal that not everyone knows these things.
