Rolling guards.
pete52m, Apr 1, 12:05pm
Anyone there doing Rolling guards properly!
paull, Apr 2, 3:24pm
mate get a pipe and as you drive forward stick the pipe between the tyre and the guard, the angle you hold it at gives you the desired roll you need, try 40mm first then make your way to 50mm pipe, works a treat and looks great, just cover the pipe in mums undies or her best skirt so not to damage the paint work,,, tell her its for a good cause
lookoutas, Apr 2, 4:33pm
Heard of a baseball bat being used. An old one! Same method as paull mentioned, and probably a 2 man/person job.
The wood has just the right amount of give.
pete52m, Apr 3, 6:41am
yeah that what im want to do. thanks for that
pete52m, Apr 3, 6:43am
yeah looks it will work but don't want to risk my guards.thanks for the comments tough
lookoutas, Apr 3, 7:08am
The risk is you. Don't blame the tools:)
whqqsh, Apr 3, 7:14am
dunno, Ive tried that on 2 cars, an old VF Valiant & my little Pinto, both just about rolled the tyre off the the rim before even looking at shifting the guard, maybe its a method 'thinner skinned' cars
lookoutas, Apr 3, 7:54am
Double skinned back guards would be hard - the fronts should move easily. My method is a good heavy block of cloth covered wood to use as a dolly, and carefully hammer the lip. It often cracks the paint around the edge.
cuda.340, Apr 3, 11:39am
heat the area where the paint is most likely to crack with a heat gun of some type, hairdryers work well, before you do the bend. the paint when warm is a bit more flexible. it don't work if its paint over bogg.
lookoutas, Sep 23, 4:17am
That's a good tip cuda
