AN Flare Savers / Conical Seals
mystic-madness, Apr 2, 3:50pm
Anyone know where these can be purchased from !, basically I have an oil leak comming from an A-N -10 fitting & rather than remove the whole fitting I found out about these conical seals. See the link & bottom of the page for what they are, http://tiny.cc/8khny
tshop, Apr 2, 3:58pm
The job wont be any easier if your fitting these instead of plain ones. Change the whole pipe n all.
mystic-madness, Sep 20, 1:12am
Well to change the fitting I have to drain the oil, remove the radiator, manifold + turbo & all lines to get the line off then refit it all. To use one of those seals I only need to drain the oil. Just looking at these for a temp fix until I have the time to swap out the lines.
