jash3,
Mar 26, 5:56pm
Copy
Alot of valve train noise any ideas!
jasongroves,
Mar 26, 6:06pm
Copy
Valve clearances need adjusted! Or do they use a shim/bucket set up!
74caro,
Mar 26, 6:10pm
Copy
Whats your oil presure/level like!
jash3,
Mar 26, 6:20pm
Copy
Ive been on line and found the torque settings but nothings changed.Its just a bolt through the center
jash3,
Mar 26, 6:23pm
Copy
The are roller lifters,Adjusted to specs and what sort of additive! Not sure which 302 it is.
jash3,
Mar 26, 6:25pm
Copy
17-23 ft lbs
jasongroves,
Mar 26, 6:40pm
Copy
Pro Ma MBL8 is the best I've used and widely recommended. Wont fix an actual problem though may quieten it down a bit.
jasongroves,
Mar 26, 6:41pm
Copy
jash3,
Mar 26, 7:15pm
Copy
No roller lifters, wish i had roller rocker
jash3,
Aug 28, 2:19am
Copy
Have an account?
Login here.
