Shudderiing and having trouble accelerating.?
millna, Mar 25, 11:26am
I guess it would have helped if I mentioned it had 200,000 km's on it.
I been having issues for the past few months with other bits and pieces, water pump, radiator. finally found out its got a cracked head
millna, Mar 25, 6:02pm
$4200 later, all fixed
millna, Dec 4, 4:38pm
Our van is shuddering at intersections if Idling for more than 30 secs and has a wee bit of trouble accelerating particulally up hills.
The car drops revs but does not stall. it just splutters and shudders
We had a few issues a month or 2 ago and had the rotor replaced. so I don't think it's that, but maybe something around it may also be warn.
It is a Nissan Largo 1997 2.4 Automatic
millna, Dec 4, 4:57pm
It has a full tank of petrol. if that helps
pete_iam, Dec 4, 5:01pm
obviously a misfire
millna, Dec 4, 5:03pm
What should we look at.
skin1235, Dec 4, 5:04pm
plug leads
pete_iam, Dec 4, 5:04pm
depends how good you are with cars. is it running on all 4!
millna, Dec 4, 5:07pm
not really that good with cars at all, it appears to be running on all 4. i.e runs great when it's cold. we only seem to have the problem once it has warmed up a bit
dave296, Dec 4, 5:10pm
The Air Flow Meters give a lot of trouble on those. its a wee square box with a plug connected into the intake near the air filter, unscrew the thing and clean the wee wirey looking bits with meths and a fine brush carefully. see if that helps.
millna, Dec 4, 5:54pm
i might put in the garage then. only problem is it only started doing it today. I often find that the mechanic can't get hthe car to play up so we sometime waste money on spark plugs etcc.
mingle417, Dec 4, 8:48pm
my mum had a problem with her garage when her Lada was overheating due to the thermostat. he said he had fixed it but it still overheated so i went round the block so the car started over heating and pissing out steam, and took it to the garage with steam still coming out, problem was fixed that day (not totally sure what was wrong with it). so try get the van all warmed up by going for a drive and take it to the garage while its still playing up so they can see excatly what you mean and might end up quicker to fix the problem
neryl1, Dec 4, 11:09pm
i think it might be the full tank of fuel. did you get it at the same place as usual. use that up then fill at mobil i reckon. my citroen didnt like bp much.
millna, Dec 5, 6:12am
I get all the petrol from the same place
millna, Dec 5, 6:17am
thanks for the tip :)
millna, Dec 5, 6:27am
I have done approx 1000k since its been in the shop
madaz_james, Dec 5, 6:29am
I reackon it your spark plug leads my mates skyline did the same thing- test them with a multi meter 7ohm good any thing after 10ohm bad and they cost about $8 each from super cheap
millna, Dec 5, 6:48am
also, no engine light is lighting up. so assume the "engine" is running fine. i.e no cylinders shot
neryl1, Dec 5, 11:59am
also get the 5th spark plug lead from the top of the distributerthe shorter one
millna, Dec 5, 12:25pm
Huh. I guess it's off to the garage.
millna, Aug 24, 1:59pm
I have just taken it for another run, the car runs like a dream when it is cold, but when it starts to warm up it shudders at intersections (seems to get worse the warmer the car is)
It has a wee splutter whn i put my foot down, but it's not too bad as it goes up steep hil;ls and runs through all the gears it needs.
