Hi all! I have just fitted a new battery into my Mitsi and when measuring the charging voltage across the battery terminals with motor running briskly I measure 13.9 to 14.00 volts on my Avometer. Is this within the correct range please! Thanks.
grangies,
Feb 1, 6:59pm
It may go a bit higher or lower, but she'll be ok.
frank1,
Feb 1, 7:37pm
Check with headlights on too--charge voltage.But from what u say should be ok.
n3d4sp3d,
Feb 1, 7:37pm
mmc specify 13.8 to 14.2 as correct charging
islaybrian,
Feb 1, 7:44pm
Thank you for your reples.It seems then that my voltage is ok so no worries!
mrfxit,
Nov 30, 2:02pm
Seems a little low but yes should be ok Always been told the best is between 14V to 14.8v 15v will cook on long distance (100km+) under 14v won't keep up with long term high drain (sitting on brake in heavy traffic at night for 30 min+ *** 14.6v at mid revs on a reasonably well charged battery would be about as good as it gets (for the medium)
