Going to attempt to fix some paint with orange peel. I found some 1500 grit for sale on here would it do the trick! Thanks in advance.
kevin_the_kiwi,
Feb 9, 12:15pm
Cool thanks mate
the-lada-dude,
Feb 9, 1:37pm
what is it !a RR i would have started at about 600 then 800 or 1200 i found a bit of dish liquid in the bucket helps use a cork sanding block with worn edges and not the palm of your hand, ( unless you really know what your doing ) cut and poliish is the fun part. mind you there are a few variables here, such as, are you sanding the colour coat or clear coat how bad is the orange peel ! i think you might be better off to go get advise from a car painter
trouser,
Feb 9, 3:39pm
Supercheap sell it. Half the price of RIPCO too.
pollymay,
Feb 9, 3:54pm
It's pretty good to. Some of the other stuff I've used the coating falls off soon after you start using it. Their 800 can die early on sanding metal sometimes but I give it hell so no complaints.
