2k Gloss clear to Satin clear?
trogedon, Feb 16, 5:07pm
Ok, sounds whack (as the yoof would say) I know but I want to clearcoat my motorbike frame. I'd rather it was a satin finish than full gloss but I only have full gloss material. Can it be dulled off! (I know, like I have been)
gunhand, Feb 16, 5:10pm
Sure can, you by matting base then tip in the required amount to gloss level you want. Expensive stuff for a one off use as from memory it only comes in 1ltr form and you use bugger all. And untill you have used a few times its hard to know just how matt it will go.
gammelvind, Feb 16, 5:32pm
Most automotive paint suppliers will do a pour off of matting base for you. There would probably be a small fee to cover the cost of the can etc. The shop that you bought the clear from may even be able to adjust the gloss level.
