Strut Brace
camere, Feb 18, 5:14pm
Where about's on the car is the front strut brace please!
granada, Feb 18, 5:19pm
On the front struts
andrea_w, Feb 18, 5:25pm
.and if that wasn't obvious enough, use this ---> http://lmgtfy.com/!q=front+strut+brace
gunhand, Feb 18, 5:26pm
strut braces tend to run over the top of the motor from one shock tower to the other or others may go from shock tower to firewall.
grangies, Feb 18, 5:36pm
Usually nowhere, unless one has been added to the vehicle.
lookoutas, Feb 18, 6:03pm
Ford's had strut braces from the 50's into 70's. Always ran from shock towers to the bulkhead at about a 45 degree angle.
The early model Mustang's have an after-marked variant called an Export Brace. These are a one piece unit joined in a V shape at the bulkhead for improved rigidity, instead of 2 single braces.
Modern versions are cross mounted after-market extras that bolt to the existing shock mounts.
lookoutas, Feb 18, 7:04pm
Here's an Export Brace
Originally initiated by Shelby
http://www.mustangdepot.com/OnLineCatalog/Suspension/images/C5ZZ-16A052-C.jpg
Standard versions were 2 single braces - not joined
owene, Feb 18, 7:44pm
Isn't a strut brace something that older ladies wear!
jmma, Feb 18, 7:50pm
Don;t give up your day job (o:
