Morris Minor LSD
gsimpson, Feb 20, 5:21pm
Is there a LSD to suita Morrie ute! A friend using one on a farm and has trouble with it in slippery conditions.
ceedoubleyou, Feb 20, 5:22pm
LOL, Morrie ute!
jmma, Feb 20, 6:04pm
A Morrie on LSD, Thats cool and far out man (o:
hi-ling, Feb 20, 6:07pm
Yep, the easiest and simplest LSD for the morrie is a common old Lincoln locker.
joanie32, Feb 20, 6:17pm
mine has 9" ford rearaxle,quitea bitof work to fit though it was
rustihammer, Feb 20, 7:30pm
My first car was a Morrie Pick-up.Great wee beastie it was too!
rob_man, Feb 20, 7:33pm
Avoid the brown LSD.
twink19, Feb 20, 7:40pm
an Anglia rear housing with lsd might be close
rob_man, Feb 20, 7:46pm
Pretty rare and expensive item, Japanese would possibly better easier to source.
sr2, Feb 20, 7:55pm
If it's a farm hack just hook up a handbrake for each rear wheel.
mgmad, Feb 20, 7:56pm
There are a few available off the shelf, not cheap though.
pico42, Feb 20, 8:01pm
Farm hack! Goop up the diff with a welder. Better tyres! Chains!
morrisman1, Feb 20, 8:08pm
if you go welding the diff I wouldnt expect the axles to last very long. They were bad enough with an open diff.
perhaps get a rear and from a datsun 120y wagon with leaf springs and put that in, then either weld it up or find an LSD for one of those.
Id just get some tractor grips then if you still have problems then go from there.
skull, Feb 20, 8:16pm
What morrisman says, the axles in those are like carrots so any effort put into that diff is a waste of time.
skydog, Feb 20, 8:41pm
I have a LSD fitted to my Austin Healy Sprite Race car.Runs Nissan A15 and 5 speed.Brought a Phamton Grip LSD in fron the USA.The Diff is the same as the Morrie Minor. $499.00 US at the time.The kit converts the diff to LSD.2 sets of springs are supplied to lock the diff. Use the heavy ones.
gsimpson, Feb 21, 6:23am
Thanks for the help. I'll pass on the info.
