i use a txture black HD paint 98606BFfor the engine its got a rasby 120 grit sort o feeling when ur hand is rubbed ove it .im wanting to acheive the with the frame
jono450,
Feb 29, 5:33pm
its an hd paint
gunhand,
Feb 29, 5:40pm
Hmmm ok. there are products that you can add to paints to stipple them or products you spray on first to stipple the item then spray over it. Ive had limited experience with themtho. When i have used it wasnt to impressed but practice makes perfect. The one you spray on first cam in a spray can. As for the matt finish well that easy as. You can use flattened solid 2Ks or basecoat with flattened clear coat.Matted clears work but find them easy to mark and you cant polish them at all, unless you polish the rest to the same gloss. Matted 2K works well. Seems the matter you go the harder it is to maintain. Im going to ask why you want a gritty feel! Thats my view on it but others may have other ideas as well.
gunhand,
Feb 29, 5:45pm
Oh, yea seen that. That is an extreme gritty finish yes. How that is done i dont know. However a good auto paint shop should know. Again others mite. And the textured finishes ive used are not that gritty. Only thing I could suggest is paint it and throw a gritty substance evenly over it while wet and paint again. I kid you not.
jono450,
Feb 29, 5:48pm
just something im trying to achive , the problem is anything other than black ,, marks when touched and cant just be wiped off because of the texture but imlikeing texture onit just want the look of halfshowroom but riddenthanks for your help much appeiceated
gammelvind,
Feb 29, 5:50pm
I wonder if that is the same as deck tread as is used on boats. Plenty of less coarse textures available, but don't come across many as gritty as OP suggests.
jono450,
Feb 29, 5:51pm
im not a painter myself but just backing myself up with your help b4 i talk to the local painters
gunhand,
Feb 29, 5:52pm
You can flatten any colour.
gammelvind,
Feb 29, 5:54pm
Marine deck tread is paintable, so it shouldn't mark. Some even sprinkle glass beads on the wet paint to give a strong, wipable non skid surface.
jono450,
Feb 29, 5:55pm
they dont do this engine paint in any colour from what i cant find
grangies,
Feb 29, 5:55pm
This stuff here is excellent and can be added to virtually all paints.
Interesting.But you cant get it in your eyes so wont be any fun to use.
jono450,
Feb 29, 6:00pm
thanks for your help i will head back out the the cave and steer and rub my headabit more wile drinking more beer and decide another plan
gunhand,
Feb 29, 6:01pm
I wasnt kidding what I sugessted about throwing grit at it. Sand that gets in wet paint and painted over dosnt go away. Ive had sand blasting sand come out of holes when painting. It makes an awsome gritty finish. And is bloody hard to remove when dry unless you attack it harshly.
gammelvind,
Feb 29, 6:02pm
Or get it in your knickers
