We have an old A & T Burt centrifugal fan (33 slp) at work which we use for blowing air through grain. At the moment it is PTO driven off a tractor so horsepower isn't a problem but we would like to know what horsepower would be needed to drive it as we have a Lister diesel motor sitting round doing nothing we would like to mount to it. I know it is an old fan but maybe someone knows something about them.
elect70,
Mar 2, 2:08pm
Need to know what the CFM is ( cubic feet per minute )@what speed , for exactHP.lister probably a bit too slow & underpoweredif its a single cylinder. my guess is needabout 5 Hp&800 - 1000RPM on the fan
pig-gal,
Mar 2, 9:29pm
Thanks for the reply, I was wrong about the motor it is actually a 2 cylinder Lombardini rated at 28hp so we shouldn't have a problem hopefully. It is governed to 1700rpm at the moment and with the pulleys we have should have the fan spinning at 755rpm. We also found a painted over nameplate on the fan today saying max revs of 900 so you're right on the money.
pdc1,
Mar 3, 7:40am
maybe working out how much fuel you tractor uses per hour, you may be able to work it out this way.
