Im wanting to lower my b1600 ute, whats the best legal way of doing this! I know you get blocks for the back. But how do i go for the front! Any help appreciated thanks
usdefault,
Mar 3, 7:53pm
Get a fat missus.
bbbottle,
Mar 3, 7:56pm
Haha thats still not legal as im on a restricted.
grangies,
Mar 3, 7:56pm
I'm pretty sure the only way it can be done is to place sand bags in the engine bay. Just add more until the desired height is achieved,
jmma,
Mar 3, 8:01pm
Get one with a full license (o: Or get two and you can sit in the middle. Then it will be even bro.
40wav,
Mar 3, 9:46pm
Why would you want to do this! Lower a B1600 and it will be good for F.All.
Mar 4, 6:24am
If you have torsion bar front suspension (which I'm assuming it has), you can simply unwind (loosen) the adjusting bolts, they should be mid way along the chassis, roughly in line with the front seats, big bastards too. Use plenty of oil on the threads. Sometimes they can seize, be careful.
On the other hand, lowering a ute is a waste of time. You will depreciate its value, defeat its purpose, make it less practical, break your back and tooth fillings, and you'll probably look like a . driving it.
usdefault,
Mar 4, 6:49am
A bit like buying a Honda then mugen.
