2770 hours - miles / km?
1coppertone, Mar 4, 5:59am
hi Im looking at buying a ride on lawn mower thats clocked up 2770 hours could someone please translate these hours into roughly how many miles or km this would have travelled.thanks 4 ur help!
grangies, Mar 4, 6:03am
Impossible to tell. As it depends on how fast the lawn mower was travelling on average.
hosky65, Mar 4, 6:08am
It's a lawn mower why are you worried about the amount of ks it's done
1coppertone, Mar 4, 6:14am
thanks i see the logic in ur answr, i didnt think to think that this lawn mower could well have just sat there idlling on blocks going no where the whole time loleven though i doubt this vry much! )
ryanm2, Mar 4, 6:14am
maybe the cambelt needs doing - it seems to be the top on everyones question list.
grangies, Mar 4, 6:23am
Even the difference between a tight lawn and an open field will make a vast difference the the K's traveled vs the hours run.
1coppertone, Mar 4, 6:23am
It's a lawn mower why are you worried about the amount of ks it's done.so i have a fair idea if it has travelled the length of nz or not and if it had id say its probably time for a rebuild and thats hard to do with money that i dont have a lot of.
1coppertone, Mar 4, 6:31am
thanks ryanm2 yvr just high lightened my need to ask present owner this question regarding timing belt.cheers!
taipan4, Mar 4, 6:39am
Also ask owner if it has nitrogen in the tyres & lightweight oil in the motor to make less impact on your lawn
twaymouth, Mar 4, 6:49am
I think what you want to know is how many hours the machine has done vs the design life of the machine. Also you want to check if it has had regular maintenance, ride on mowers work very hard and if not maintained can die early deaths or cause lots of grief for unwary owners.
1coppertone, Mar 4, 7:03am
thank you twaymouth i will check to see if it has been maintained regularly cheers 4 that!
skully13, Mar 4, 8:08am
If you think of it this way, it has done 69.25, 40hour weeks of work/running.
thunderbolt, Mar 4, 8:25am
This mower has done 277,000 km, if it was traveling at an average of 100kph for its whole working life.
m16d, Mar 4, 8:30am
If it was a car,it would have done about a quarter of a million k's.
I'd say it's worn out.
jmma, Mar 4, 8:33am
What make of ride on, year and size/type engine! would help in making some decisions
woody1946, Mar 4, 8:38am
What colour is it !
corky, Mar 4, 9:40am
Looks like the model beside it has done more hours than the mower.
quickbuck, Mar 4, 9:59am
If you really want to know, then it would be about 5000k.
Now you have that, what use is it!
IF it were a car, it is half way to its first oit change. But it isn't it is a lawn mower. So you look at the condition based on what you see, not by how many K's it has done. Just like looking at a car really.
IF it were a car, it is half way to its first oil change. But it isn't it is a lawn mower. So you look at the condition based on what you see, not by how many K's it has done. Just like looking at a car really.
quickbuck, Mar 4, 10:00am
Did somebody mention cutting grass.
jason18, Mar 4, 1:18pm
Gas grass or ass
holdenboy11, Mar 4, 2:11pm
Don't forget to include time sitting at traffic lights/intersections.
matarautrader, Mar 4, 2:18pm
As previous posters said maintenance is the key. My old ride on got an oil change every 4 years whether it needed it or not. Also had a bad habit of having a wheel fall off!. The mowing we used the ride on for varied from a very easy stalk topping to attacking 2 foot high kikuyu grass ( with stones, old posts, wire etc hidden inside. Ran over a spade one day left by our neighbours in long grass and that cost a new set of blades.
jmma, Mar 4, 2:22pm
If a contractor uses his little 5hp briggs mower for say 20 hours a week, then that's 1000 hrs a year and they usually get 5 or 6 years out of it.
I would say the ride on with a bigger motor and maintained should well be OK at 2770 hrs.
Just divide hours by number of years old, that will give you some idea of use.
1coppertone, Mar 4, 3:23pm
thanks 4 ur help and tha use of al ur brains, maths was never a favarate subject along with my spellling. but 1 thing Im good at is mowing lawns and Im now pretty sure il b buying this suckr. lolthanx a lot pple!
