Fuses keep blowing
cmjury1, Mar 24, 6:05am
in my indicators so i changed the fuse blew again i changed the fuse in the hazards and the indicators and it still blew. what could be causing this!
panicky, Mar 24, 6:08am
a short
cmjury1, Mar 24, 6:09am
so ill need to take it to a auto electrical!i wonder how much they charge cant be cheap
morrisman1, Mar 24, 6:12am
depend on how long they take to find the fault
skin1235, Mar 24, 6:20am
have you or anyone else fitted a new bulb recently, or had any other issues, has it had a broken light recently
cmjury1, Mar 24, 6:22am
not since ive had it. someone did suggest it could be something to do with the bulbs but it first done it 3 months ago auto elec put 2 new fuses in and it was fine up until thurs
r15, Mar 24, 6:37am
Check the condition of your trailer plug and associated wiring in the boot area if the vehicle has or has had a tow bar
cmjury1, Mar 24, 6:48am
never had a tow bar by the looks of it. i looked in the boot at the wiring all looks normal to me but i dont know how to get the door panel off or where the wiring goes lol
skin1235, Mar 24, 6:51am
basic steps are remove all indicator bulbs, fit new fuse, try indicators, if it blows the fuse, take the vehicle to an auto sparky, if it doesn't blow the fuses turn the hazards on and fit one bulb at a time, check each bulb before fitting for sagged filaments etc, or discoloured glass ( such will likely indicate the errant bulb) easier if you fit the two on one side of the vehicle, the bulbs will glow continuous until there are at least 2 bulbs in the system,, if you find one that pops the fuse, replace it, you may actually get all working without issue, the action of removing and later replacing the bulbs often clears a minor short from rust or wet dust
cmjury1, Mar 24, 6:58am
i pulled the tail lights out and the filament in the indicator bulb looks screwy.
thank you skin1235 ill give it a go.
intrade, Mar 24, 6:58am
probably a wire chaved thru and when the bulb was changed light had to be removed is my guess so the wire now makes contact with the car body and pops the fuse. thats my guess of what could have happened. would mean the car probably had a accident at some stage also on where the wire is worn out. unless it is a mercedes with biodegrading wiring loom then you are in for big bux wire could also have been damaged on refitting the light after changing bulb.
intrade, Mar 24, 7:00am
check the socket for corosion it could have a short in coroded lightbulb holeder.
cmjury1, Mar 24, 7:00am
not a merc thank goodness but i have a feeling it was in a accident before i got it cos sections of the paint are slightly different shades.
thewomble1, Mar 24, 11:31pm
has the correct bulb been fitted.some have 1 contact and others have 2.not interchangeable.
Are you using the correct size fuse.heavy enough to do the job.
johanes, Mar 25, 11:32am
check reverse light wiring under vehicle
cmjury1, Mar 25, 12:00pm
the fuses i was putting in are what it says on the cover to use.
cmjury1, Mar 26, 10:51am
fc8k stupid car. i dropped it off at the auto electrician this morning just ring him and he says there is nothing i can do. i checked all wiring all is fine i put 2 new fuses in and its working fine! grrrr
sr2, Mar 26, 11:02am
Good advice but the Merc ???biodegradable wiring??? problem was only in the engine loom.
richard198, Mar 26, 2:09pm
You fixed it!
You must have removed the short when you were working on the taillight.
(Like skin1235 suggested)
cmjury1, Mar 26, 5:34pm
i must have done something i dont know what thou lol
must have been somewhere in the tails lights aye cos they were the only thing i fiddled with.
now im just worried when i use the indicators it will happen again lol
i am prepared i have a couple of spare fuses in my wallet
cmjury1, Mar 26, 5:40pm
the only thing i have noticed since i got it back today was that when i lock it with the remote the indicators dont flash but thats ok i may be picking up my new car on wed. as long as this one gets its wof tomorrow
