Bugga! Need help.
sr2, Mar 26, 6:47pm
Off on tour with my band for a week and in the process of giving the legendary Ducato band van a quick birthday discovered I was getting no pedal and a huge amount of air to the rear brakes. With the obvious diagnosis being master cylinder failure during bleeding I had it rebuilt at a well known (in the trade) Auck brake shop.Just finished a 2 hour fitting and bleeding session with exactly the same symptoms! It??
jmma, Mar 26, 8:15pm
Why were you bleeding the brakes in the first place!
johnf_456, Mar 26, 8:39pm
Probably just periodic maintenance, brake fluid does absorb moisture
flat_white_ltd, Mar 26, 8:40pm
Car cologne. Menthol chewing gum. No baked beans or curries.
She'll be right. . & break a leg
carmedic, Mar 26, 8:40pm
Are you trying to bleed them with it jacked up at the back!
If so it needs to be on the ground or a four post hoist and level due to the load sensing valve on the back.
jmma, Mar 26, 8:51pm
Thanks sr2 for that answer (o:
andrewph, Mar 26, 9:35pm
Hire a bigger van and sacrifice the dog anyway. LOLI suppose they did drill out the holes in the cylinder! (including the ones to the resevoir) I've had that happen. Tried blowing out the lines with the air! If all else fails PANIC. Bench bleed the cyl! good luck.
hijacka, Mar 26, 10:55pm
Wonder if the slave cylinders are just as old as the old leaking master cylinder! Most cases the master cylinder would have taken time to wear out and by replacing it you increase brake pressure 10fold and pop goes the cylinders. Thats where i would look to first. ''brake slave cylinders'' if that's the problem, do both sides with new shoes and machine the drum and check the shoes seat inside the drum properly before assemble.
sr2, Mar 27, 9:13am
Thanks for all the advice guys. I was just replacing the fluid when the problem occurred.Hopefully we??
mugenb20b, Mar 27, 10:31am
You're weird.
sr2, Mar 27, 11:05am
LOL, you're not the first to notice that and probibly won't be the last!
snoopy221, Mar 27, 12:41pm
(incorrect cup covering the compensating port) but it doesn??
sr2, Mar 27, 12:53pm
You may well be right there Snoops, fixed the problem with a pressure bleeder but I'm still not convinced it was the problem in the first place.
flat_white_ltd, Mar 27, 12:55pm
No,, belky,.mate, it wasn't weird.
The man was simply pointing out that Johnf was replying ( with an erroneous guess) to a question put to the OP
.nothing weird about it, & most reading appear to have got that.
(edit:). None of which, of course, helps mr SR2 out.with his brake issue,. excuse the digression :)
flat_white_ltd, Mar 27, 1:01pm
or. wrong sacrifice to the gods !
sr2, Mar 27, 1:06pm
LOL; and here was me considering sacrificing the damn keyboard player!
flat_white_ltd, Mar 27, 1:08pm
well, . that's what the good lord gave us sequencers for :o)
.but keep him on. it can get lonely up on stage on yer own.
johnf_456, Mar 27, 1:22pm
Do share why, I try to be a nice and friendly person. But I no idea whats up your nose.
Do share why, I try to be a nice and friendly person. You can't judge a book by its cover. Peace.
johnf_456, Mar 27, 1:26pm
Was just answering post #2 question, yes it doesn't help sr2. But just answering and stating info about brake fluid. Easy mate (0:
flat_white_ltd, Mar 27, 1:37pm
j John. you're doing fine.
no need to post a reply to this., .just move on. - all good.
(don't sweat the small stuff, kay ! )
