20valve 4age blacktop running rough in 2nd and 3rd
samage, Mar 27, 7:03pm
when driving my toyota carib in 2nd and 3rd gear it runs like a sack of spuds on acceleration feels like its struggling to breath or something untill about 3500rpm then it comes right. any ideas what the problem could be!
samage, Mar 27, 7:04pm
its a 1997 5speed manual as well
samage, Mar 27, 8:07pm
anybody!
samage, Mar 30, 9:29am
no ones got a clue!
nikki834, Mar 30, 2:05pm
plugs/leads/coils/fuel regulator
in that order.
ceebee2, Mar 30, 2:19pm
Complete service as above from nikki for starters unless you can offer more info on service history etc. Guessing can be expensive in a forum.
ema1, Apr 1, 9:09am
Have a diagnostics check done the read out should point you to the problem!
Without a hands on diagnoses it could be one of several things that's why the diagnosis (computer) check to show fault codes would be the best thing in your case.
I'm wondering if possibly the fuel pump is failing and isn't supplying enough common rail pressure or there is an ECU or sensor fault.
Possible the O2 sensor could be "naffed"!
Then again it could be another sensor or something completely unrelated at fault!
samage, Apr 1, 3:31pm
ok thanks for the comments will get it looked at
