For some reason my oil tank (separate oil and fuel tanks) has filled up with fuel - any ideas(no i havent filled the wrong one).
Thanks 1985 Johnson 140 VRO in a Plylite Panther
dr.doolittle,
Mar 30, 4:34pm
I'm no expert but. I understand some outboards rely on a vacuum to feed oil to the mix. Check your lines for leaks & that the hoses are connected correctly. It might somehow be sucking fuel back intothe oil tank. Ring a MARINE specialist.
martin11,
Mar 30, 4:35pm
Do not run it it probably will not get any oil into the vro and seaze . oil tank needs cleaning out and reprimed the oil system Take it to a good outboard service man How long have you had it !
dr.doolittle,
Mar 30, 4:36pm
I'd look at disconnecting it & running premix.
xs1100,
Mar 30, 7:10pm
+1 a lot easier and chuck some moreys upper cylinder lube in at same time (does not replace 2 stroke oil) 30 mls to a tote tank
