Is there a Carburetor that can replace the Hitachi
nomannz123,
Apr 5, 11:53pm
The Hitachi Carburetor with Water Choke, is there a compatible Carburetor that does not have the water choke that can be used on the 1989 Japanese import Mazda Familia! If so where could I buy one!
Apr 6, 1:53am
you can just disable the joke in to the off position i have had to do this on nisans also bit hard to start in winterdont know how cold hammilton gets but up here they drive the car now 3 years with no choke assuming that that is the part that is faulty on yours. And if you can find a carb that bolts on then you can likely use that what ever as a carburettor is just a way to mix petrol and controll the amount mazda familia is also called a 323 or laser so any carb from these could potentially work if they have the same intake manifold
rob_man,
Apr 6, 8:47am
A DCD Weber would do the job.
muzz67,
Apr 6, 1:52pm
fit a cable to make the choke manual!
rob_man,
Apr 6, 1:54pm
Too obvious, surely.
Apr 6, 1:57pm
you cant fit a cable to make a auto choke manual lol i would like to see you do that
rob_man,
Apr 6, 2:02pm
You can on some carbs.
Apr 6, 2:05pm
probably but not on the nissan well you could when you would engeneer and machine parts . so anything is possibile but you could also make a whole new carburettor then lol
rob_man,
Apr 6, 2:28pm
But it's a Mazda. anyway, I'm not familar with that carb but if they have a butterfly and a mechanism to open and close it, a cable is an option to at least consider.
pebbles61,
Apr 6, 2:51pm
SU carb conversion! :D
nomannz123,
Apr 6, 10:40pm
Hey guys I am taking the carburettor in to the local carby shop here in Hamilton and I will ask him if it osiible to convert to a manual choke. I have thought of that but there are a few things to be looked at first. Will see what he says there! Tahnks
berg,
Apr 7, 5:26am
Baby two barrel Holley. We used to fit them to Mitsis in place of the original carb. Takes a bit to sort the jetting out but good options when its done.
muzz67,
Apr 7, 3:33pm
Done 3 so far, easier than sorting knackered auto set ups.
doug207,
Apr 7, 6:24pm
This. Throw the Hitachi rubbish out, useless damn things.
aredwood,
Apr 7, 7:11pm
I was able to disable the auto choke on my 4AF powered corolla with a piece of wire on the side of the road. Did it when the alternator broke, on that car the electrically operated auto choke was fed by the alternator off the same wire that goes to the battery warning light.
nomannz123,
Apr 7, 10:51pm
Yo dudes, this carburetor has a number of solenoids and vacuum hoses running all over the place. I wonder where half of them lead to.
doug207,
Apr 8, 2:53pm
Will have auto enrichment, air bypass, accelerator pump etc etc. Weber upgrade!
