Old Rover carb
jmma, Apr 7, 5:03pm
Son is putting a Rover in the demo derby, I think its a P5 mid sixties, 3 litre six cylinder auto and can be any colour you want it to be (o:
Problem is fuel leaking badly out the bottom of the big old S U carb, took it apart and I would call it the choke diaphram is split.
Anyone know where to get one of these or maybe an old carb lying around!
jmma, Apr 7, 8:27pm
Back to the top you go (o:
jgig23, Apr 7, 9:00pm
Swift Automotive Ltd
jmma, Apr 7, 9:07pm
Thanks for that, will check, but demo next Saturday and looking for a quick fix.
Could seal it temporary but can't think of anything that petrol won't eat, in saying that, it only needs to last a little while.
jgig23, Apr 7, 10:46pm
Hope that helps, just got a warning from TM for giving out contact details.
jmma, Apr 8, 6:49am
Its a bugger when that happens when you are trying to help someone, some narks never sleep (o:
socram, Apr 8, 8:17am
Not sure what part you are referring to!Metal!Rubber!Not really aware of a diaphragm on an SU carb.Post a pic!
hi-ling, Apr 8, 8:32am
The P5 rover was fitted with a SU HD8 carby and on these the the float bowl mounts with its arm fastening directly below, and concentric with, the main jet. The arm has a flange that fastens with 4 screws to the bottom of the carburetor, and sealed with a rubber diaphragm integral with the main jet.
I have 2 carbs sitting here but wont supply parts to someone whos going to destroy a semi classic car. Thats what we import jap shit for.
jmma, Apr 8, 9:02am
Yes, you have described it exactly, I can appreciated where you are coming from with destroying a semi classic. He did get it from the wreckers and it is in a not to good a shape.
With a bit of luck it will destroy a few jappas before it is laid to rest (o:
I could seal above the diaphram with some sort of gasket poo, as not going to use choke, but any suggestions as to what to use!
hi-ling, Apr 8, 9:19am
I would use Permatex Fast Drying sealant; it is brown and funky but works
well on fuel if you leave it an hour or more to dry. Or if you cant find that, try Hylomar Blue, although petrol proof, it is not suitable for constant immersion in the stuff, but if your only using it for 1 day it should be fine.
hi-ling, Apr 8, 9:23am
Another is permatex ultra blue
jmma, Apr 8, 9:30am
Thank you hi-ling
BTW he does appreciate classics, as he is restoring an EH and a HG Holden, also he used to be on here as bigjerry, until he got a permanent ban
hi-ling, Apr 8, 9:47am
Okay I wondered what happened to bigjerry. All good, I just hate seeing any of the old cars destroyed.
jmma, Apr 9, 4:08pm
Thanks hi-ling Permatex ultra blue did the trick, bigjerry thanks you.
