I my snorkel for my terrano has separated. Its in a very hard place to get to. Under the left hand front panel right up near the top. I have tried some sealant and putting a jubilee clamp on it but it still comes apart. Does anyone know of a really good, glue that would join to together. Both ends are plastic. Thanks
figjam999,
Apr 17, 7:11pm
go to bunnings or any plumbing outfit and buy a plumbquick the appropriate size
vandewc,
Apr 17, 7:19pm
Whats a plumbquick!
figjam999,
Apr 17, 7:26pm
it's a rubber tube with a hose clamp at either end
vandewc,
Apr 17, 7:28pm
wouldn't be enough room to put one on. Theres only about 10mm max between the two parts.
figjam999,
Apr 17, 7:32pm
pretty easy to get on, mate had the same prob with his hilux, the tube is only about 5mm thick, remove the hose clamps, slide tube over one end then slide back. reattach clamps
Apr 18, 4:07pm
the other way might be to use screws to holdf it together
r15,
Apr 18, 6:49pm
or there is another goo they sell at plumbing stores but i cant remember the name of it. it was kinda dark grey in colour when it was wet.it has been holding a stainless fitting onto a loose fitting plastic pipe on my spa now for 3 years. thick as, sticky as, and drys really rubbery
