GTO Transmisson?
dasfi, Apr 30, 4:23pm
Looking at a gto with a blown trans, yea i know there crap but i like them,
Seems pretty hard to find a second hand auto trans for them ,anything else from the mitsi range that has same gearbox! cheers
cuda.340, Apr 30, 4:29pm
do a Diamante engine/trans swap. dirt cheap to buy.
dasfi, Apr 30, 4:55pm
how bout just a diamante trans! is it the same!
phillip.weston, Apr 30, 5:01pm
Most Diamantes of that era are FWD rather than 4WD so no a Diamante trans wont work unless it's the 3.0 4WD one which is hard to find. Even so I think the Diamante trans may be just that little bit different to the GTO one.
bubbles244, Apr 30, 5:01pm
GTO is 4wd
you need the gear box from a E-F27Adiamante
and not the second generation one they use mivec engine
the GTO 3l v6 has more similarities to the v6 pajero then the later diamante
bubbles244, Apr 30, 5:04pm
when it comes to bolt patterns that is
lyndapotty, Apr 30, 5:41pm
Hit up the people on GTOPerformance.co.nz, a bunch of good guy's that will most probably have a spare trans lying around.
dasfi, Apr 30, 7:11pm
sweet as was maybe looking at one but found a trans hard to source
