hi all i hav a 83xr that has lost 3rd gear ,i have just bought a 87 motor with a droped velve, wat i would like 2 kno is shud i just slap my barrel/piston/top end on the 87 or shud i use parts from the 87 to fix the 83 thanks for your advice
motorboy2011,
May 2, 3:14pm
Easiest way would be to use your 83 head on the top of the 87 motor.
motorboy2011,
May 2, 3:14pm
Easiest way would be to use your 83 head/cylinder/piston on top of the 87 motor.
kaymay88,
May 2, 3:42pm
this is what i would do, assuming they are compatible.
cheeky39,
May 2, 3:46pm
cheers thats what i was thinking just wanted to make sure thanks
mbikeman1,
May 2, 4:23pm
yup will swap over,the later model top end may have been slightly bigger 192 to 194cc but apart from that all will look the same
motorboy2011,
May 2, 4:36pm
you dont by chance have a spare engine side cover do you! stator/alternator side
