Catalytic Convertor has a hole
melinda1, May 5, 9:17am
A mere female here but I have a '89 mazda familia which ws jerking a couple of different days recently, stalled and restarted okay.Couple of days later stopped and wouldn't restart.A friend- no mechanic- lifted hood and could see a hole in the catalytic convertor.Could this be the cause of my car jerking, stalling and not going and is it smething that could be replaced without going to garage!Any other ideas appreciated. TIA
a.woodrow, May 5, 9:22am
Cut it out and weld in a bit of pipe.
desmodave, May 5, 10:37am
Take a picture and post on here
melinda1, May 5, 12:58pm
Will try and take a pic thanks-could it be the cause of car not running/running rough!
pettal, May 5, 1:45pm
Are you able to see the catalytic convertor from the engine bay !,thought they are normaly a bit further back !.
marte, May 5, 3:59pm
Then sell the convertor to a scrapmetal yard.
shuddupowh, May 5, 4:04pm
#5 thats exactly what I was thinking. The cats sit about 2 feet back from the exhaust manifold so are not visible from the engine bay. but may be an odd car so never know.
ema1, May 5, 4:30pm
Japanese import Mitsubishi Mirages had em bolted right up front and it sort of formed part of the exhaust manifold from memory.
I replaced the one on my parents( now mine since they have both passed away now) old Mirage CGF 1500cc 1985 model with a NZ new manifold , bored and tapped a hole to remount the O2 sensor and never had a problem from then on. It had the electro jet carby on it!
neville48, May 5, 8:02pm
Just do as #2 and #6 suggested and cut it out, put a piece of pipe there, and sell the cat to a scrappy. the car will run better and the scrappy will probably give you 80+ bux for it. Win Win situation, you dont need it.
ema1, May 5, 9:00pm
Manifold & cat unit was cracked is why I replaced it, that was in the early 1990's
hondalova, May 5, 9:42pm
sr18de primeras have cats attached to manifold directly.
a18a, May 6, 8:49am
I've had a couple mazdas with the cat bolted to the exhaust manifold. does the car feel really gutless and underpowered!
olsod2, May 6, 11:01am
had a car that stopped running.a mate took cat converter off then rammed a steel rod in its guts,remounted it.car then run like a dream
mbikeman1, May 6, 3:05pm
$80 damn,down here we would be lucky to get $15 from any of the local scrappys,And to top it off we would have to tell them its a convertor otherwise they would just pay steel price
alltorque350, May 6, 6:13pm
Is the hole where the O2 sensor should be! Does the hole have an internal thread!
desmodave, May 7, 6:28am
Thats what i was thinking but abit hard to tell if ya cant see it
marte, May 7, 10:55am
I'm not sure, But I think Simms gives you $60 per cat.
