LMFAO
hobnobcob, May 7, 10:31am
award for most ridiculous use of pod filter!
Listing #: 467157792
tatts2, May 7, 10:33am
Maybe someone should tell him they go over the end of the exhaust.
bellky, May 7, 10:35am
I actually think that's not a bad idea.
richardmayes, May 7, 10:37am
That should really boost the performance outta sight, compared to running the stock air filter.
Awesome.
ninja_man, May 7, 10:37am
it might have pretty good response haha
rob_man, May 7, 11:20am
Can't see a problem with that.
ofive, May 7, 11:24am
doh way to slow down the air intake
n1smo_gtir, May 7, 11:25am
fark i shouldda done that with my old corolla carby. that's kiwi ingenuity, i have never thought of that. if he extended it and sectioned it off from engine heat, it prob run pretty sweet.
bellky, May 7, 11:26am
Yes a K&N (factory spec) air filter replacement would be the ideal.
bitsy_boffin, May 7, 11:33am
To be fair, may be as simple as the old oem one was shagged and he couldn't readily get hold of the right replacement so took it out and stuck the pod on the end instead because it happened to fit and be off-the-shelf.
inkapuka, May 7, 11:43am
Double filtration lol
kwkbrk, May 7, 11:51am
Dammit. I was going to take the factory filter out of my Benz V8, and put one on the front of each snorkel that goes to the front of the car !
Not now, in case one of you buggers notices and laughs at me !
outbidyou2, May 7, 12:03pm
that be some clean air
rob_man, May 7, 1:19pm
It's pretty obvious there will be no element inside the filter housing.
hamishcookie, May 7, 1:40pm
Right above the exhaust manifold, location location location
