2 stroke engineers/builders
bigfatmat1, May 7, 6:17pm
Can any one recommend someone able to undertake porting and recoating of two stroke bores In new zealand
snoopy221, May 7, 6:20pm
Porting ain't hard just remember you want to lift the intake transfer and exhaust ports for power and r p m.-only nead 1 to 2 mill shaving.
As to nikasil coating!
what's the 2smoke!
A lot of aftermarket piston/bore kits around nowadays
bigfatmat1, May 7, 6:29pm
Cr 250
By bore kit do you mean steel sleeve. As this is not an option as they effect the temp and cause other problems.
Cr 250
Porting would involve epoxy and some special tools to get in some of the places as well as computer aided design
kingfisher21, May 7, 6:31pm
Boss Engineering, Wanganui.
steve312, May 7, 7:23pm
NZ Cylinders in Christchurch.Not cheap but great finish.
snoopy221, May 8, 2:17am
Cr 250 M1! M2! OR M3!
Back in the day you used to be able to get the**Thumper** kits
ported barell and o/s piston.
mytbe some still around on ebay!
drog, May 8, 8:03am
The first things to try before you mess with the ports: 1. Optimise the squish band and make it work properly. 2. Make a PROPER pipe that matches the exhaust port timing. There is nothing to be gained by using a 10k rpm pipe on a 8.5k rpm port.
rod-zone, May 8, 11:38am
You can "champfer" the top of the piston down on an angle at the port areas.just don go to close to the ring land.beats having a crack at a Chome bore and stuffin it up
Gav
