2 stroke oil anywhere from 10:1 to 50:1, depends on what year, what size, what carb, etc
msigg,
May 15, 3:04pm
You could use the 30 grade or 30/40, they will run with anything.
red97,
May 15, 3:20pm
i use 30-40 at 10 to 1 at that ratio anything remotely slippery will be fine if your not leaving an oil slick your not using a seagull
trogedon,
May 15, 3:24pm
I still remember the smell of dad's one as it sat on the back of the boat and chugged along.
a.woodrow,
May 15, 3:28pm
Haha so true. great wee motors.
ladatrouble,
May 15, 3:39pm
Seagull's have bronze bushes for main bearings, and not much in the way of oil seals - so that's why 30 oil at 10:1 is recommended. But I found they went well on 2 stroke at 25:1 (lawnmower stuff of the period). I would get no start Seagull's in at spring time - by the time what little petrol is in the mix evaporates the carb is just full of oil.
rsr72,
May 15, 3:45pm
#4- Yep. Always love the sound of a sweet-running one.
snoopy221,
May 15, 4:30pm
Shouldactuallyhave written on the fuel cap-half a pint sae 30 oil to a gallon
r15,
May 15, 4:43pm
we have successfully run one on BP98 & Castrol TTS @ 40:1 and also with 95 and Valvoline outboard at 50:1 for hours on end
(the fuel was bought for mx bikes and jetskis )
ralphdog1,
May 15, 7:13pm
Here is a quote from Wikipedia: Models manufactured from 1931 to 1945 had a recommended petrol-to-oil mix of either 8:1 or 10:1. From 1942 models specified a 10:1 mix which was specified up to 1979. After that date a 25:1 mix was specified, which was again changed for the introduction of the models 125 and 170, but these engines with the 50:1 mix soon failed, and British Seagull again specified 25:1. This relatively high percentage of oil was necessary due to the way the crankshaft bushings worked. Early engines used short bushings, and later ones used longer bushings, hence the changes in oil requirement. The longer bushings were, in fact, used from 1967 onwards, and the engines from 1967 to 1979 can be used on the 25:1 mix by making carburettor adjustments.
mrchilt,
May 17, 5:09pm
cheers i have made a out rigger on my kayak and have strappeda seagull on to it
snoopy221,
May 17, 5:19pm
Get yaself a TAS. Search on trade me 1 hp TAS air cooled damn near a quarter of the weight of a seagull. (Actually damn near HALF the weight of a pair of average dingy oars.)
