Dot Dot Dot and Dot Dot Dot Dot
v8_mopar, May 10, 5:06pm
I think dot 3 boils faster than dot 4 or 5 but why can you only use dot 3 in some cars thinking dot 3 is lest desirable and others only dot 4 etc
a.woodrow, May 10, 5:08pm
I believe it depends on the seals used in the brake hydraulic system
skiff1, May 10, 5:42pm
also viscosity bt the way DOT stands for department Of Transport spec
rayzor14, May 10, 6:46pm
A wide range of answers.
In general silicon fluid will be problematic in older vehicles and is not a great performer over all.
There is also the question of dry boiling point (for those who get serious about stopping from speed)
Race Brakes NZ have a good write up on their website explaining the various fluids, their properties and what is recommended.
phillip.weston, May 10, 7:18pm
Dot 4 and Dot 5.1 (not to be confused with Dot 5) supersede Dot 3. Your car will say Dot 3 because Dot 4 (and 5.1) wouldn't have been produced at that time. You can use Dot 4 and 5.1 in place of Dot 3.
tonyrockyhorror, May 11, 1:50pm
F@rk'n Spot on, Bevan.
bellky, May 11, 2:03pm
Yes^. Some systems require Dot 3 only. Castrol Response Dot 4 can be used in all Dot 3 applications and most Dot 4 applications.
The 'superseding' thinking is simpleton thinking.
phillip.weston, May 11, 2:49pm
why would Castrol make a product called Dot 4 if it can't be used in all Dot 4 applications but can be used in all Dot 3 applications! Dot 4 meets and exceeds the Dot 3 specifications and can't imagine there being any negative consequences of using Dot 4 in a Dot 3 applications.
bellky, May 11, 3:08pm
It's Castrol Response Dot 4 and there's something in some Dot 4 fluids that can perish/swell the seals in Dot 3 Only masters/slaves.
You can still buy brand new Dot 3 Only clutch masters.
Castrol also make Castrol Response Super Dot 4 for '95 and later Dot 4 applications.
tonyrockyhorror, May 11, 3:48pm
Rubbish. DOT4 is entirely backwards compatible.
bellky, May 11, 3:58pm
You don't know what you're talking about again. Talk about backwards compatible.
v8_mopar, May 11, 5:06pm
This is good
I think I'm better of for it :/ well I think so
thewomble1, May 11, 11:48pm
But will DOT 3 mix with DOT4 etc
snoopy221, May 12, 12:04am
Bra show moi an asian mawree.
or a german mawree.
and ya'll LEARN 5.5.1.
Oh as to the waitangi backwards DOT.
LMFAO.
snoopy221, May 12, 12:06am
sHORT cIRCUIT-=[dAMN good old movie. ROBOT=number FIVE.]
LOL
tonyrockyhorror, May 12, 8:37am
This just in: bellky knows better than the manufacturers of the brake fluids.
Yeah, right.
bellky, May 12, 9:17am
No idea.
Edit to say you have some idea - but not enough.
gadgit3, May 12, 9:25am
Toyota had a large recall last year on early model Highlander brake master cylinders and it all came back to wrong type (Dot) of fluid used in brake fluid changes causing swelling of the seals. and what Bellky is saying is correct for this model.
tonyrockyhorror, May 12, 2:27pm
I have much more idea than you.
tonyrockyhorror, May 12, 2:34pm
They recalled because the material was incompatible with anything except 'genuine' Toyota fluid which has added polymers. It was simply poor material selection for the seal, nothing to do with the DOT rating of the fluid.
bellky, May 12, 2:35pm
No you don't.
tonyrockyhorror, May 12, 2:40pm
Yeah, I do. Ten fold.
bellky, May 12, 2:41pm
You don't.
morrisman1, May 12, 3:04pm
Look guys, my e-penis is bigger than all you so no point even battling it out
gadgit3, May 12, 3:20pm
Really thats not how it was worded in the TSB. or the recall info
