Bump stops and WOF
cybertrades, May 10, 4:47pm
Got told that my front wheel drive 99 pulsar will not pass a warrant because the right hand front bumpstop needs replacing.Is this an actual warrant requirement or not!
a.woodrow, May 10, 4:49pm
Is it missing or damaged!
cybertrades, May 10, 4:49pm
Missing so im told.And he quoted $170 for one side and shock shop will do it for $75
foxdonut, May 10, 4:51pm
nah bro. They're purely for cosmetic reasons, don't actually do anything except make your car look stupid cuz its too high. You should just take them out and not worry about it.
a.woodrow, May 10, 4:53pm
Yep it's a wof fail
cybertrades, May 10, 4:55pm
Yeah ill do that after the warrant
martin11, May 11, 12:44pm
Rubbish They are there for a reason
foxdonut, May 11, 12:55pm
Well, please explain in great detail for us then.
martin11, May 11, 1:05pm
Why should I bother if you do not know why the vehicle manufacturers put them on ,you are just showing your ignorance about motor vehicles
floscey, May 11, 1:07pm
they stop metal to metal contact when you hitlarge bumps and reach end of suspension travel. Probably stops metal fatigue and possible failure .meh. its only steering .totally overrated .
martin11, May 11, 1:10pm
Just do not buy one of foxdonuts old cars they may have cracks in the rails where thebump stops were
petemun, May 11, 1:16pm
just chuck roller blade wheels on the shocks. bro.
elect70, May 11, 1:17pm
stick a rubber door stopon it
poppajn, May 11, 3:43pm
Is it just me or what!. There,s some good omformation given out on these post,s but then you get absolute plonkers like #4, #13, #15that just post absolutely jolly, blimen rubbish. Just urninates me off.
stevo2, May 11, 3:46pm
^^^^^^^you are #15
doomy999, May 11, 3:48pm
yes I agree with you
Especially that one at 15.
steve98h, May 11, 5:47pm
yes missing or modified bump stops is a fail for a wof. they are there to limit suspension travel when hitting a pot hole or speed bump etc. rear 1s are also importent, have fail a wof on a hilux before because the owner had lowered it and removed the rear ump stops, the diff had been hitting the chassis and when he took it to the panel beaters the pretty much wrote if off, had to go have major chassis repairs and a cert.
