To whoever designed
morrisman1, May 8, 6:26pm
the engine bay of a Toyota Curren: YOU SUCK!
Clutch job is an absolute nightmare. Enough said.
a.woodrow, May 8, 6:53pm
Hehe let me guess the firewall mount!
nathan84, May 8, 6:55pm
cut one of the bolts off easy as
mugenb20b, May 8, 6:59pm
Yep, I sometimes think that the "designer's" son in law was a mechanic. I do a lot of clutch jobs myself, mostly 4WD utes, pricks of things (not hard, just awkward), especially Mazdas, because the gearbox sits at an angle, so the useful flat surface that you need underneath, suddenly makes your life a nightmare. Another shit one is a Nissan Terrano, the torsion bar front suspension needs to come out.
morrisman1, May 8, 7:02pm
yeap the firewall mount was an absolute bitch. Not looking forwards to putting it back in, thats for sure. Any tips!
I found that access to anything in this vehicle is hampered by useless things like plastic encased wiring looms and other silly things that shouldn't really be there. Why they decided to mount the engine off the gearbox is beyond me, why not make gearbox independent, it would make it much easier!
Here is the clutch that I removed:
http://i264.photobucket.com/albums/ii200/morrisman1/_MG_0353.jpg
a.woodrow, May 8, 7:03pm
Aye try an alfa romeo, one of those early alfasud things, have to drop the engine to get to the top bell housing bolts
a.woodrow, May 8, 7:06pm
Hehe somewhere in my toolbox I have special part no 9661 - a15mm spanner i cut the end off and bent over to fit in the mount. I know it was supposed to be a 14 mm but I wasn't prepared to sacrifice the 14
mugenb20b, May 8, 7:06pm
Oh, shit! LMAO!
mugenb20b, May 8, 7:07pm
That's what cheap spanners are for (or someone else's).
skiff1, May 8, 7:09pm
on the bright side, at least it was worth doing!
unbeatabull, May 8, 7:14pm
Or the Mondeos where you have to drop the complete front subframe off
a.woodrow, May 8, 7:14pm
looks like they got their money's worth. Morrisman is handy with a welder aint he! could mig that up and chuck her back in for another turn.
morrisman1, May 8, 7:16pm
This car was pretty much nana driven on the clutch which was new 6 months ago, then a noob manual driver thought it would be cool to do a burnout. Doesn't look like it was the wheels spinning! Perhaps he will respect other people's cars a bit better now
morrisman1, May 8, 7:19pm
Mig! what do you think I am! Professional it must be! I've got a stick of knead-it here which will do the job nicely.
a.woodrow, May 8, 7:21pm
Yep ok cut some strips of leather for the clutch plate and bob's your aunty
morrisman1, May 8, 7:27pm
Im gunna go all fancy and put a ceramic clutch plate in: just gotta drill and spline the middle of mum's finest china
modie61, May 9, 1:17pm
Thought those Toyotas went forever ! Most reliable and simple and easy to work on !
rob_man, May 9, 1:22pm
I have heard it alleged that the X-member that gets in the way can be forced down with the torsion bars in place and a couple of wooden blocks wedged in somehow to make enough space for the box to come out.
smac, May 9, 1:39pm
Tried towing my mates mazda B1600 uphill from a standing start in my pa's MKIV cortina once. Through all the smoke there was indeed flames coming out of the bellhousing.
Cooled it off, got another 50k out of that thing before he traded it.
foxdonut, May 9, 1:51pm
Lol.
Spinning the wheels in a Curren.
Do they even have that much power!
Edit: I know is a 3sfe so yeah, it probably could with enough motivation.
morrisman1, May 9, 8:03pm
3sge, 180hp
sw20, May 9, 8:08pm
morrisman1, does your name imply an interest in Morris motor vehicles!
The same Morris that decides to put the brake fluid reservoir in the floorboards of a Minor!
tshop, May 9, 8:17pm
Most front drive head work & or clutch changes isn't easy, removing suspension, engine mounts & multiple connections is standard fair. Job is a 5 spanner difficulty rating 4 sure.
morrisman1, May 9, 8:22pm
servicing the morry brake master cylinder is easy, as long as the guy who installed it put the nuts on the outside of the car. If they put the bolts on the outside then you have to take the torsion bar off to get it out!
cowlover, May 9, 9:27pm
Can't yoy just cut the heads off the bolts and then put the new ones in the other way!
