Photography guys
petermcg, Apr 5, 11:20am
Cant find the rite thread,,
I need to take pictures from a book in the archives that i am not allowed to photocopy from what sort of camera do i need. megapixles SLR etc
socram, Apr 5, 11:57am
Any modern digital camera, compact, SLR or video will do, but make sure that what you are using it for is 100% legal!Switch off the flash.
Why is this in the motoring section!
fryan1962, Apr 5, 12:33pm
no flash as stated above and depending on what size you want to blow them up too
might be photo of a car lol
craigsmith, Apr 5, 1:25pm
Do use the flash if you're not worried about getting caught. Hold the camera above the book as square and as high as possible to minimize perspective distortion, fill the frame with the spread using zoom, use as high a shutter speed as possible. Set the flash to compulsory. If the pages are glossy then watch out for highlights from the flash spoiling the result, alter the angle a little to avoid, if not glossy will not be an issue. Obviously the better the camera the clearer the result will be. It's not a scanner but It is possible to get decent results.
fryan1962, Apr 5, 1:27pm
I have used flash and it has washed out pic before
he would be better in NZD some of those guys are good with close up camera work
socram, Apr 5, 2:36pm
Most modern cameras are fine in natural light.No point whatever in using flash.
petermcg, Apr 5, 3:25pm
Thanks its all above board, the books are delicate and cant be handled a lot,(like Me) I would like an SLR but might have to go for an imitation.
fryan1962, Apr 5, 8:58pm
when I was overseas, I bought top of range compact it is awesome
wellystretch, Apr 5, 9:43pm
MACRO MACRO
MACRO MACRO
tigadee, May 8, 9:42am
If you have plenty of natural light, then just use the camera without flash. Make sure you rest the camera on something or else use a tripod if you have one. If you need to use flash (like in a dark place), move back and zoom in, and switch on macro mode. That reduces the intensity of the flash and prevent washing out of the image.
petermcg, May 8, 3:31pm
Just to update I now have aNikon D70 and trying two different lenses, one is 18-70mm and other is 28-85mm with macro, all of trademe.
