Does anyone know why a mercedes e230 would be driving along and then lose 80% of it's power then will make it to the side of road you turn it off and turn it back on again and it goes fine! it used to only do it when you would come to a stop know does it all the time. It also has a very strong lag when taking off at intersections you can put your foot 90% down and it will have very little pick up for the first few seconds. any ideas what this could be!
pettal,
Apr 4, 3:03am
fuel filter !.
tmenz,
Apr 4, 5:07am
Do these cars have knock sensors! Sound like it's going into some sort of 'limp-home' mode!
Apr 4, 5:08am
Or a fuel pump.
gypsypom,
Apr 4, 5:12am
fuel possibly, once had a toyota that did this finally worked out it was the fuel cap air hole was blocked an creating a vacuum in the tank
goldie51,
Apr 4, 6:52am
ahh that could be it. I will look at the fuel tonight. also seems to me making a cracking kind of loud sound when it finally clicks into power.!
dunkalicious,
Apr 4, 7:25am
My car is doing this to and i have no fuel cap on the car! could this be the cause, its literally doing exactly what the original post says. I know is hould of replaced it but its been off for like 6 months now. If that could be would it be just a matter of putting a cap on or do i have to do something else!
goldie51,
Apr 4, 8:19pm
Dunkalicious. does yours have a back seat!
Apr 4, 8:24pm
what year is it it could be caused by biodegrading wiring loom early to mid nighteen 90s are equiped with selfdestructing wiring bio looms need replacing if it is the case about 2500$ cheaper when you get em remade with old plugs
Apr 4, 8:25pm
you would have to drain all the water in the tank from the rain also when fitting new cap
karstuff,
Apr 4, 8:32pm
I believe fuel caps are now checked in the WOF procedure.Not having one may present problems.
andrewph,
Apr 4, 8:53pm
Common problems on e230 the air flow meter, the ign coil packs. get it scanned. that will most likely find the problem the quickest.
goldie51,
Apr 6, 9:20am
Thanks Andrew I will definately do that, do you know how much a scan usually costs and can most mechanics places do it!
ceebee2,
Apr 6, 2:20pm
Take it to an Auto sparky, they have them.
ceebee2,
Apr 6, 2:20pm
Average price is $80-$100
