are they adjustable, I have the type you can pump grease in with a grease gun , If i tighten it and grease it will this work, failed wof due to slight play
carmedic,
Apr 14, 5:05pm
You cant tighten/adjust it however the 'pumping grease in with a grease gun' might have that affect if its VERY slight play. Also how much is slight play! The manufacturer specifys that the maximum lateral deflection must not exceed 3.18 mm. When jacked correctly (under lower arm).
petermcg,
Apr 14, 5:18pm
Come see me I will supply you with a new one
