Cert or no Cert
bubbles52, Jul 2, 3:03pm
Would like to change my Nissan Navara Diesel ute to a petrol using the petrol motor from a Navara, it will bold straight in without any modifications, will i need a cert for this or do i just got to vtnz and say its a petrol now!
berg, Jul 2, 3:29pm
http://www.lvvta.org.nz/documents/standards/LVVTA_STD_Engine_&_Drive-train_Conversions.pdf
Look at section 4.3
Unfortunatly as you are changing fuels you will need a cert
intrade, Jul 2, 3:51pm
you also will have to change the gear ratio dont know if its done in the transmission or the differential. plus you have to change all and every fuel hose as they desintigrate with other fuel flowing thru em. usually they burn to the ground after you got the cert all done i seen plenty burned out conversions.
bubbles52, Jul 2, 5:08pm
they are metal fuel lines
steve312, Jul 2, 5:11pm
Only the main length of the fuel line is steel.There is definitely still going to be a flexible fuel hose at the engine/filter end and many also have another flexible hose at the tank.
bubbles52, Jul 2, 5:29pm
thats not a problem, I have access to a whole deregistered petrol navara
bubbles52, Jul 2, 5:40pm
the petrol one is rusted out and is a real dog, my diesel one is mint condition, just want petrol as the diesel one TD23 is a bit gutless and continuously paying RUC when you rack up 5000kms a month.
bubbles52, Aug 20, 2:44am
Vechile is 2wd D21 Navara, thought about repowering with TD27 Turbo, but is a bit expensive at this stage.
