12v Wiring
primemeat, May 27, 1:55pm
In a 12v system what is the blue and what is the brown!
ryanm2, May 27, 1:58pm
in a 230 volt system blue is neutral and brown is phase/active. Do 12v systems have coded colours!
sirdoug, May 27, 2:08pm
Tell us more. What are you trying to do.!
saxman99, May 27, 2:11pm
Need some more info, could be absolutely anything.
primemeat, May 27, 2:12pm
3 way fridge. I want to put a plug on it but only has a blue and a brown wire and I dont want to blow it up!
bitsy_boffin, May 27, 2:13pm
Err, a 12v system means you have two choices, either it's positive, or negative, really doesn't take a rocket surgeon to work out which is which, and I'd suggest that brown is most likely the negative.
Now if you are in fact, as I suspect, talking about installing a car stereo, then this is a different question entirely.
Edit: ok you're not talking about stereos.
saxman99, May 27, 2:15pm
So, it's already got a 230V AC mains plug, right!
bigfatmat1, May 27, 2:15pm
brown positive blue negative on most things 12v but I have also struck several items prewired with these colours that are the opposite
bitsy_boffin, May 27, 2:16pm
If it's a 3 way fridge, then I would suggest you have got hold of the mains wires there, blue and brown are standard colours.Don't feed 12v into those!
primemeat, May 27, 2:19pm
It has a fixed mains plug already. It has 12v written on the wire.
bitsy_boffin, May 27, 2:22pm
Then it really could be either direction.
If it were me, I'd probably take it apart to trace the wiring and look for an indication which is which.
saxman99, May 27, 2:23pm
What make & model fridge!
primemeat, May 27, 2:31pm
Consul Discovery 60l
primemeat, May 27, 2:48pm
Pulled it to bits. Brown is Neg and blue is pos(as I suspected). Thanks to all who helped.
msigg, May 27, 5:42pm
bisty-boffin was on the money. Good on ya
