Octane boosters?
dave653, May 23, 11:56am
Thought I'd use the bottle of Wynns 'Race Formula' octane booster I had in the shed. They reckon it increases the octane rating by up to 5 points. Have adjusted the timing so it doesn't pink on 95, put 30 litres of 91 in with the Wynns, and it pinks under mild loud pedal. Obviously the 'booster' doesn't do it's job, I'll be going back to 95, as it's cheaper to use anyway. And. yes, I have seen the youtube story on the various brands.
jasongroves, May 23, 12:05pm
Edited because I am pretty sure I was wrong there.
From Wynn's site:
'Increases the Research Octane Number (RON) by 2 to 5 units.'
jasongroves, May 23, 12:10pm
30L 91 RON @ $2.158 = $64.77
30L 95 RON @ $2.229 = $66.87
How much was that bottle of 'Race Formula"!
dave653, May 23, 12:10pm
Well, that explains a lot! Just thought it was crap.
dave653, May 23, 12:11pm
Was $14 at Surplus Direct.
jasongroves, May 23, 12:15pm
Hang on, on another of their sites:
'Increases Octane Rating By Up To 8 Units'.!
dave653, May 23, 12:19pm
Definately 5 points, 'To stop pinging (not prevent) and reduce valve seat wear'.
jasongroves, May 23, 12:22pm
Ah, I was right.'points' or 'units' are exactly that, points.so 'up to 0.5 RON increase.'
jasongroves, May 23, 12:24pm
Some interesting reading for those that are interested;)
http://www.fueltechexperts.com/2008/08/08/octane-boosters-which-is-best/
dave653, May 23, 12:44pm
Good read! Of course, it's cheaper to use the correct fuel instead of buying cheap. and adding expensive additives. So many new, or near new, car owners are cheapskates, I hear so many pinking it's not funny. The difference between 91 and 95 in my 73 litre tank is only around $5.
jasongroves, May 23, 12:48pm
The octane booster producers don't make it very straight forward when it comes to their claims.confuses me a little anyway (the units and points part.)
floscey, May 23, 12:49pm
go fill up with BP ultimate 98 .
kiwaza, May 23, 2:29pm
Use either Gull Force 10, or add 10% ethanol to any brand of 91. Replace your resistor plugs with non-resistors (preferably multi earth.) You will notice smoother running and performance gains.
jasongroves, May 23, 3:28pm
Remember though, that Gull and/or BP Ultimate fuels may not be available where the OP lives.
jasongroves, May 23, 3:29pm
And of course, fuels with ethanol are not suitable for running in all types of vehicle.
I for one, have no idea what the OP drives.
n1smo_gtir, May 23, 10:19pm
sorry but what exactly are resistor plugs!
motorboy2011, May 24, 6:24am
I wondered the same
kiwaza, May 24, 7:35am
Resistor plugs have a resistor built into the central electrode. Ifthe letter 'R' appears in the middle of the plug part number, it is a resistor plug.This supposedly reduces RFI or EMI but it also reduces the amount of current available for forming the spark meaning less complete combustion and reduced performance. The unburnt fuel then passes into the exhaust system where it is burnt by the catalytic converter. The truth from my observations, is that non resistor plugs produce no RFI, because the plugs are well shielded by the engine block and cylinder head - no RFI can escape. If RFI is such a problem, why are petrol engines in aircraft and boats alway required to run non resistor plugs! These applications often have sophisticated computerised fuel management systems yet RFI is never a problem. Serious race motors never use resistor plugs.
kiwaza, May 24, 7:41am
I disagree. Tell the Brazillians.
dave653, May 24, 8:40am
Tried that a few years ago in Tauranga. 12c/ltr dearer than 95, didn't notice any difference in power, economy of general running. on a 400km trip, or the weeks running around town after I got home.
dave653, May 24, 8:44am
They are here in Whangarei, but my old engine won't benefit from it at the moment. However. I am about to fit a new, angrier 202 so higher octane juice will probly be required.
patiki1, May 24, 10:19am
I'll be adding toluene when i get my baby running
delerium1, May 24, 11:33am
octane booster is not a substitute for proper octane fuel, it also eats away at the electrodes of your spark plugs.
elect70, May 24, 11:37am
I used that 104 + in my chargerworked wellon 11:1 cr
pauldw, May 24, 12:12pm
