Sump Plug threads stuffed
sterid01, May 24, 9:07am
Hi guys my sump drain hole has been threaded on my dirt track car and replacing the whole sump is not an option , do you guys have any suggestions I was just going to clean it and coat with thread locker . It has to be reasonably good as we have some long races ahead .
woki, May 24, 9:12am
Both thread surfaces will have wear .Get rid of the old sump plug and try fitting a brand new sump plug .
bjmh, May 24, 9:20am
BNT sell a oil drain repair kit .has taps to suit plugs .your friendly garage might sell you the plug you need and let you borrow tap
poppajn, May 24, 9:24am
Run a thread tap thru it
serf407, May 24, 9:26am
Find the best mechanic possible to do the best threading insert. A mechanic who does this on a regular basis to a high standard.
i.e mint correct sized drill and the correct thread insert.
Find the best crispest threaded replacement sump plug. Right sort of thread treatment on the sump plug before tightening to correct torque.
sterid01, May 24, 9:44am
Ok thanks guys
serf407, May 24, 10:47am
Another way depending on the sump material/ shape etc can be to get a turner to put an internal thread in a piece of round bar. Weld a piece of metal over the old sump plug hole so the pilot drill is kept centred. Hole saw out the sump plug hole and weld in the piece of round bar.
poppajn, May 24, 6:09pm
Would a Helicoil work here!
hijacka, May 24, 6:16pm
Macgyver would use chewing gum.
m16d, May 24, 6:33pm
Yer can JB weld the plug in but if ya do that you've got to do the same with the filler plug.
pollymay, May 24, 8:12pm
I'm cheap, I'll wind it in and weld it there/drill it right out then carefully drill another hole and weld a new threaded insert or nut on there with a bolt.
Gotta watch for metal shavings left in the sump though.
ceebee2, May 24, 9:06pm
I have simply welded a nut on the sump, easy as.
