87 impulse CDI
sathan81, May 21, 10:59am
Where would be a good place to find a CDI for a 1987 Impuse GSX! I have had no luck on TM or local bike places.
TIA
ola.thorsen, May 21, 12:49pm
ambo11, May 21, 3:19pm
You want a CDI, or is it stuffed coils, and stalling when really hot! These things were terrible for having crap coils and dying when hot unless the revs were up around 3000 or more. Mine was a nightmare, ended up getting newer GSX-R 750 (I think) coils fitted and presto, problem solved.
ambo11, May 21, 3:21pm
Also since you are in Levin, Roger at Levin Motorcycles would instantly know what the problem would be, he's the Suzuki expert, or used to be.sold my Impulse may moons ago.cool wee bike when they are going right.
tonyrockyhorror, May 21, 3:30pm
geoff_m, May 21, 8:32pm
Gsxr2250 cdi can be used but you need to wsap 2wires .My impulse has gsx11 coils. Stock are unreliable.
Erd cdis are ok. Dont believe the extra power claims tho.
clark20, May 21, 9:23pm
Nearly bought one of those new, had a good motor but was known to throw a rod if thrashed too much. Was only$4500 new, as we (NZ) got them cheap as they were not too popular with the different look.
kazbanz, May 22, 6:29am
Clark --the leg out of bed bit was mostly the guys that cut the red wire. -ie the rev limiter wire
kazbanz, May 22, 6:44am
OP--as stated above several times
1) check your coils first as they were prone to crapping out and
2) ER and D for repulse cdi units
