Hi, does anyone know if a Delica coloum shift gearbox will bolt up to a wide block 4g63 starion block
phillip.weston,
May 20, 4:40pm
depends if it's from a 2.0 petrol, 2.4 petrol, 2.5 diesel, 2.8 diesel or 3.0 V6 petrol.
Starion engine block has the 'wideblock' 330mm dowel spacing which is shared with the 2.4 petrol 2WD, 2.0 petrol 4WD and 2.5 diesel blocks. You cannot use a gearbox from a 1.8/2.0 petrol 2WD, 2.8 diesel or 3.0 V6.
