do your burn of the paint of the inner of the dryer with a heat gun or leave it (small debate about this i havent in the past but hubbys reckons we should)
grangies,
Jul 4, 1:12pm
Not sure.
But what to you use for a door on the dryer!
purplegoanna,
Jul 4, 3:17pm
its the old fashioned standup closet dryer so its all there ready to go you just remove the motor at the bottom, add a pan or wok of ti-tree sawdust light a gas ring underneath and away you go they even have hanging/drying racks allready in them, theyre really hard to find but we found this one under a old house for sale.
unclejake,
Jul 4, 3:50pm
If you are using gas then I wouldn't bother taking the paint off, but you are better asking someone on the fishing.net.nz forum
illusion_,
Jul 4, 6:26pm
if it's gonna get hot enough to do anything at all to the paint you'd better not be putting any fish in there
olsod2,
Jul 5, 12:32pm
this is going to be a smoker not a cooker.how hot did this use to get as a clothes dryer remember it had a heater which dried clothes.i used one of these,had an old electric fry pan in a seperate container with a metal down pipe between the two and cold smoked my fish.
donz01,
Jul 5, 6:05pm
We used to use an old upright type 1 years ago (a bit bigger than a standard fridge). We did not burn the paint off and used to fill it with hams and smoke them with manuka sawdust. It worked great sitting up on a brick base(where we lit a small fire before using the sawdust to make the smoke) From memory the base was 3 besser blocks high.
i-n-horz,
Jul 5, 8:09pm
Lol.that's exactly what I was think'n.
purplegoanna,
Jul 5, 9:32pm
we gonna try set it up for both.
purplegoanna,
Sep 3, 3:00am
yip the last one i had was set in a bank about 1mtr up we had the fire at the bottom of the bank and a flue upto the cabinet.
