Yes, given the km's etc its worth more than the other one you looked at, assuming its in as nice a nick as it looks, I would buy a tidy example for that. No harm in arm twisting them a little though. The only real negative with that one is thanks to the dopey importers its probably not got air conditioning.
By the way, are you buying a "weekend car" and a cheap commuter as well! If so have you done the math and considered a car that will fill both needs!
Roughly how many km's is the work commute and is it all stop start travelling! I was just wondering about fuel consumption, although the Bravo is very good consumption wise for its output its not a 1000cc puddle jumper. That said actual running cost may be here nor there if you are not doing massive milage or if its not in grid lock traffic.
