Noisey release beaing?¿¿
lazz323, Jul 5, 8:19pm
i heave recently been hearing like a tapping noise coming from engine bay, i thought it was my tappets getting real bad real fast, but i then soon realized the noise went away after i put my foot on the clutch.i am certain its the release bearing. This only started happening today, any chance anyone would know how much roughly how much it will be to fix/adjust! or maybe more will i need to add more clutch fluid! i haven't checked it yet fluid levels yet but yeah my partner does drive it around.
lazz323, Jul 5, 8:26pm
could it be the release bearing!
mrfxit, Jul 5, 8:37pm
Sorry but the crystal ball is away getting repaired from last time someone asked a question like yours.
What make /model of vehicle & gearbox
lazz323, Jul 5, 8:42pm
mitsubishi lancer glxi 1999 , unsure of gearbox
rkauto, Jul 5, 8:52pm
not release bearing,will be gearbox.
lazz323, Jul 5, 8:53pm
141kms :) 1.8L
bopbargains, Jul 6, 4:54am
if the noise goes awaywhen youput your foot onthe clutch it wontbe the release bearing. it willbe the input bearing in the gearbox.
tonyrockyhorror, Jul 6, 12:31pm
Correct.
mrfxit, Jul 6, 1:01pm
Time to check your gearbox oil levels & condition.
May still be ok with a better grade of oil.
woki, Jul 6, 1:10pm
Release bearings generally dont click , the might rattle but not common . Could be a number of things . Find a friendly mechanic , most workshops have one and get a qualified opinion .
mrfxit, Sep 6, 3:10am
Yep could be anything of .
Crook release bearing
Loose /cracked clutch plate
Loose/cracked pressure plate
Front gearbox bearing
Front gear cogs with to much end play
loose spigot bearing
Yea ok so some of those are rare BUT.
