What octane for 351C
likit, Jul 14, 11:45am
What are you guys using,my 351c I would classify as mildly tuned, what would you recommend!
jasongroves, Jul 14, 11:59am
Personally, I would be running 95.
But without knowing the tuning/timing specifics its hard to say.
Getting a tune with an exhaust probe attached to get actual air/fuel ratios correct with the fuel of your choice would be the way to go IMO.
lookoutas, Jul 14, 3:44pm
You haven't really told us a lot.
How old!
likit, Jul 14, 4:06pm
74 2V heads
mopeds, Jul 14, 4:07pm
Low compression is fine with 91, higher compression or charging needs 95.
lookoutas, Jul 14, 4:31pm
You might find it'll suck more 91/km than it would using 95.
Don't forget to put an additive in for the valves.
quickstitch, Jul 14, 4:44pm
half n half 91 and avgas. mmmmmmmmmmmm the smell
dragu, Jul 14, 5:14pm
yeh half and half 98 and c16
johnf_456, Jul 14, 5:45pm
Nothing like the smell of avgas thats for sure quickstitch
extrayda, Jul 14, 5:50pm
Id run 95 in it depending on the compression and cam profile. Ran my 10:1 HQ on 95 and it was happy. In fact I run all my cars on 95. Wouldn't put anything less in it.
quickstitch, Jul 14, 6:07pm
C16, whats that worth now ! $200+ a drum! At least i was getting Avgas at the same price as 95 octane at the pumps.
likit, Jul 14, 6:17pm
I presume the additives are still available from s/stations!
extrayda, Jul 14, 6:23pm
How old is the motor! If it was rebuilt, it may already have hardened seats! I got mine set up to not need the additive.Wouldn't bother with anything more than 98 at most, as the motor won't need it.
likit, Jul 14, 6:27pm
It is a 74 motor & has been sitting in my garage for last 5 years,finally getting it up & running,I would say motor has had some sort of rebuild but not sure about hardened valves.If I put additive in would it cause any damage if they had been installed!
grangies, Jul 14, 6:30pm
Good post John.
sr2, Jul 14, 6:33pm
Yes it was non-confrontational and sounded almost normal, well done there John.
quickstitch, Jul 14, 6:57pm
awwwwwwww, so i can't abuse him for that post. i will save it for next time then.
grangies, Jul 14, 6:57pm
Absolutley Simon.
quickstitch, Jul 14, 6:59pm
if the motor has 302 heads on it it will need/love it
peejeles, Jul 14, 7:05pm
nitro methane
extrayda, Jul 14, 7:15pm
He didn't say 302 heads, just 2v heads.If they are 302 heads it's not going to be very happy even on 98 I wouldn't have thought.Hopefully they are just 351 heads and it will be fine.I owned a car once that had to have octane booster / best gas in it all the time - never again, too much hassle.That was why the HQ 383 was set up to run on 95 happily.OP are they 302 or 351 heads!
likit, Jul 14, 7:19pm
351 heads
sr2, Sep 11, 10:02pm
I couldn??
