Wanted sum1 rb exp
alcoholic_borri, Jul 13, 1:09pm
Wantd some1 to wire up my 98 STAGEA WGNC34 25DT mota into my gtst4 price neg manawatu area pref
ezekiel67, Jul 13, 1:17pm
Do you want someone with an angry face or is that optional!
tonyrockyhorror, Jul 13, 1:20pm
Are you kidding! The angry face is integral to getting the job done right! Anyone who's smiling is probably a snake oil salesman.
alcoholic_borri, Jul 13, 1:27pm
Gts4 manual, i changd front diff fasier as mota was owt its al gud to go just gota b wird n,h got the standard 20 dt loom and the 25dt loom that bjum wit mota , i had a go at it bt ecu end of 25dt is way didrnt then the 20 loom misgng heaps plugs, and ecu plug is a grey blue color and ond the 20 it is dark blue, and thdm 25 ecu cnt plug into the 20 ecu plug
alcoholic_borri, Jul 13, 1:30pm
ezekiel67 wrote:
Do you want someone with an angry face or is that optional![/quote
]angry people get the job done and usualy dnt talk rubbish and throw tools round good fun
grangies, Jul 13, 1:33pm
A sphincter says what!
alcoholic_borri, Jul 13, 1:50pm
Who would make the custom loom!i was going to make the loom but so hard to find ecu pinouts and stuff like that
alcoholic_borri, Jul 13, 2:01pm
Dam 4x4 such a dam pain
alcoholic_borri, Jul 13, 2:11pm
Yea gtst original just dif mota, just emaik nzefi for a price website say start from 600
andrea_w, Jul 13, 2:28pm
Seriously!
Have you actually tried looking!
Typing like an adult and not a 14 year old kid may help your cause too.
alcoholic_borri, Jul 13, 2:35pm
Yes i have looked, instead of being a smart arse why dont u tell me where to look. .,and you try typing on a little touchscreen cellphone keyboard
alcoholic_borri, Jul 13, 2:50pm
Nzefi would need my car and engine down there in chch and would cost 600 bt cnt get my car there so scratch that idea
antwerp87, Jul 13, 2:57pm
That deserves a few awesome technical correctly spelled statements
1: LOL
2: ROFL
3: LMAO
4: ROFLMAO
antwerp87, Jul 13, 3:00pm
This deserves 1 statement
+1
andrea_w, Jul 13, 3:26pm
Oh don't get me wrong, I can maintain the smart arse attitude AND tell you where to look.
www.google.com
I'm sure I have the pinouts of an R32 RB20DET ECU on my pc. I stumbled across them on (.you guessed it) the net! via an overseas Skyline forum I post on
antwerp87, Jul 13, 3:31pm
SNAP! And the OP doesnt reply for 24 hours
alcoholic_borri, Jul 13, 4:02pm
Well that wasnt so hard now was it hope u not talking about skylinesdownunder
andrea_w, Jul 13, 4:15pm
No it wasn't hard. but are you seriously implying you couldn't figure out for yourself google was the best place to look!
Not talking about SDU as I said 'overseas', but if you go on any site like that and talk like you have been on here, you will not get a pleasant response. In general, people on those forums don't take kindly to people typing like a 14 year old. I know you said you had a reason, but you will get no where typing like that on SDU/SAU/SO.com etc so spend a bit more time typing it out in full ;)
Why would you 'hope' I'm not talking about SDU!
falcon15, Jul 13, 4:36pm
i have never done a 4wd engine but have wired plenty or rb25det into skylines, laurels ect. On the rwd engines the rb25det ecu plugs into the 20det loom all you need to do is change over all the injector plugs to the rb25 ones and at the ecu swap the injector 4 and 6 pins around and run a constant 12v feed to the vvt plug and run a earth wire back to the ecu. i cant remember which pin it goes into without looking at a diagram
alcoholic_borri, Jul 13, 4:46pm
If you refer to the first post i was ofering to pay someone because i cant be botherd
alcoholic_borri, Jul 13, 4:49pm
Thanks falcon except the 25dt ecu wont fit
falcon15, Jul 13, 4:59pm
Do you have the full 25det engine loom. It will probly just be easier to get that full loom wired into your car. It shouldnt cost much the nissan looms are pritty basic and easy to wire in. It shouldnt take a decent auto sparky to long
tnt423, Jul 13, 5:05pm
I used a rb20det loom, cut the injector plugs off and put rb25det injector plugs on, then had to swap one other plug to get it to work. Took about an hour. The loom in the engine bay is the same between rwd and 4wd, lots of info on the net about how to wire it up just need to spend some time searching.
alcoholic_borri, Jul 13, 8:11pm
Yes i have full loom i can do motor side easy as its the ecu end under the dash wea the problems are
falcon15, Jul 14, 6:16am
It should be a easy job to wire in the 25t loom. Theres only 3 or 4 power feed wires that need to be connected. your r32 would have these power feed wires down by the left hand headlight but the 25t loom takes the power feed wires from a plug under the dash so you will need to extend those wires. then all you need to do is work out the tacho wire, water temp wire and oil pressure wire on the 25t loom and splice them into the dash loom
