Trans
j.jsmum, Jun 10, 11:07am
are you ment to check transmisson oil level on car when engine is running or when the engine is off
cuda.340, Jun 10, 11:09am
check the level when it's hot, some are checked while ideling in nuetral.
henderson_guy, Jun 10, 11:09am
Running.
mugenb20b, Jun 10, 11:23am
Depends on the type of car you've got.
unbeatabull, Jun 10, 12:10pm
9 times out of 10 it will have it written on the dipstick when to check it. Most will be either running in park or running in neutral and above a certain temperature.
red97, Jun 10, 1:19pm
some models have to be checked whilst in drive and running, i find if you follow a ute closely with the bonnet up then someone on the back of the ute can lean in and check it for you.
unbeatabull, Jun 10, 3:23pm
I don't understand this post!
If it has to be checked in drive, put it in drive and crank the handbrake on then get out and check it yourself!
motorboy2011, Jun 11, 6:38am
Wooooooooooooooooooooooosh
tonyrockyhorror, Jun 11, 7:24am
Man! That was pretty low-flying!
ema1, Jun 11, 11:12am
He he .might have been a UFO!
carclan, Jun 11, 3:17pm
Consult with the owners book as it should have a procedure unless it is like my BA Fairmont and no longer has a level stick.
purple666, Jun 11, 5:47pm
Best post I have seen in a coons age.
